copy sound from one side of earphones to the other?
hello I was wondering if there was a way to copy sound heard from one side of earphones to the other side? what i mean is that Im listening to an instrumental but when I have both earphones in my ear the sounds are weird to me, in with only one earphone the instrumental sounds great. what I wanted to know is there a way to copy that part that sounded great to the other side of earphones that didnt sound great ?
Try to get another copy of the song. It sounds as if it may have phase cancellation.
If necessary you can use the Audio Track Dropdown Menu to split the stereo track, then select the part you want to copy in that channel only. Edit > Copy.
On your keyboard, ENTER, DOWN arrow, ENTER.
Edit > Paste.
