converting
i have saved my work as save as then i reloaded it and exported it to a wav file but the convertion only lasts 1 hour 13 minutes 59 seconds everytime no matter how long the work is. is there a reason for this
Even if you export a fifteen second test?
How long is the show in Audacity?
If you have a long file you could be running into the WAV file size limit of 4GB. If you have a WAV file 4GB or greater try saving as FLAC (or almost any other audio format).
