convert separate parts of an audiobook into one file?
How to convert separate parts of an audiobook into one file?
Hello everiybody. I’m a newby and need to convert 38 parts of MP3 stereo ebook into an one MP3 stereo ebook file. My sys: Windows x64 SP1 and Audacity 2.0.2. I would appreciate step-by-step instructions or address where I can find them. Thanks for help. M.
If you just want to be able to play the 38 parts one after the other, there is no need to edit the files, just create and use a playlist: http://en.wikipedia.org/wiki/Playlist
Many audio players provide simple ways to create and save playlists.
Hello Steve. Thank you for the reply and the prompt. I’ll try to do it and post the results. Thanks. M.
