Controlling the volume of effects
In using effects, I was unable to control the dry vs wet mix of the effect. In other word, the volume of the effect itself. One or two of them had dry volume controls, but most did not. How do I control the mix of the effect into a select track (mono)?
Can duplicate the track, (“Ctrl”+“D”),
apply the effect to the duplicate,
and mix it with the original un-effected (dry) version using the track gain sliders.
Frank,
Sorry, I accidently-temporarily edited your post instead of replying…
And Trebor, I fixed the quote in your post…
In using effects, I was unable to control the dry vs wet mix of the effect. In other word, the volume of the effect itself. One or two of them had dry volume controls, but most did not. How do I control the mix of the effect into a select track (mono).
Most effects don’t work that way but usually there’s a way to adjust the “amount” or “strength” of an effect.
What effect(s) are you using?
Yes. Start there. It’s possible you are just using the effect wrong.
