Hello,
I am looking for ways to achieve the following:
Use the current input value of a specific control to dynamically update the value of a different control/field.
If this cannot be done without executing/running the script is it possible to accomplish something similar to a parameter
“refresh” that does not close the gui or apply the final script as in “preview”?
For example:
If the current value for the frequency of a tone is 60 in control 1,
and I need to see what that value times 25% subtracted from 60 is in control 2, (which would be 45)
where the value of control 1 would be called generate a 60hz tone in the right stereo channel
and the value of control 1 would be called to generate a 45hz tone in the left stereo channel
This is a simple random scenario. I hope it paints a clear picture.
Any thoughts?
