connecting sony ps-t1 turntable for audacity
I am running windows 8.1 pro and audacity 2.2.2. I am at a loss. I hope I am just missing something but I simply cannot get my old Sony PS-T1 turntable to speak to audacity properly. I realize that this is not a top of the line turntable and is 30 years old but it plays perfectly on a sound system and works fine for me.
Here is the scenario.
I replaced my old receiver a number of years ago and the new one does not have PHONO IN inputs. No preamp. The turntable also does not have a preamp. I figured this out after trying to initially connect. Of course I just dumped 2 old receivers last year and they both had the preamp built in. I was able to test the turntable on a friends old receiver with preamp and it works perfectly. So it is not the TT. The HP J2900 tower I am using does NOT have any rca inputs. Just microphone input, blue audio input and usb ports, both 2.0 and 3.0.
I bought a Behringer UF0202 preamp to USB but that doesn’t work. The sound comes through but very faint and pretty distorted. I played with all the combinations of the input settings with nothing seeming any different. I also bought an adapter with 2 RCA to an 1/8" plug (3.5mm)( stereo ) and used directly to audio or microphone input with same success. The sound is there but at maybe 10% and appreciable distortion. Also in conjunction with Behringer as well with no change.
I hope I am just missing a setting or maybe it is something with windows. I was hoping I could get some help here. I have hundreds of pristine vinyl that you can’t even find anymore and would love to get them onto CD’s. All I need is some quality sound getting into audacity to make that happen. Didn’t think it would be this difficult. Can anyone help me out?
Thanks in advance!
The Behringer should work (assuming it’s not defective). It uses the Microsoft-supplied USB audio drivers so it should be plug-and-play (although the Windows setting can sometimes get messed-up).
Make sure you’ve selected the USB device as your [u]Recording Device[/u].
Then if you can record but you can’t hear what you’re recording, make sure you’ve got the correct Playback Dvice selected (typically your regular soundcard) and make sure you’ve got [u]Software Playthrough[/u] enabled.
The HP J2900 tower I am using does NOT have any rca inputs. Just microphone input, blue audio input…
… I also bought an adapter with 2 RCA to an 1/8" plug (3.5mm)( stereo ) and used directly to audio or microphone input with same success.
None of that will work. The mic input has a preamp but there is no [u]RIAA Equalization[/u] so you’ll get a lot of high frequencies and no bass.* It’s the wrong impedance (which will reduce the signal and probably mess-up the frequency response even more), it’s usually a low-quality preamp, and it’s sometimes mono.
The blue line-inputs will work with a “tape output” from an older receiver that has a built-in phono preamp or you can buy an analog [u]phono preamp[/u].
The [u]ART USB phono interface[/u] can be used as an analog phono preamp and it has a gain/level control which is a nice feature because you can adjust the level before it hits the ADC so there’s less chance of clipping (distorting) your ADC.
  • It’s possible to apply the RIAA EQ after recording but I wouldn’t recommend that solution, especially if you want the best possible quality.
