I’m trying to record sounds from a Stylophone S1 connected to my PC via the microphone jack.
If pressing the red record button in Audacity and play the Stylophone S1, I can see the soundwaves appear in the stereo channels but obtain no sound through the headphones.
When pressing play, I can head the soundswaves, but I can’t find the way to hear what I’m playing when recording.
Any ideas?
Thanks
Turn on Audible input monitoring.
But… There is always SOME latency (delay) through the computer and depending the delay it may be hard to perform. You might need to use a Y-Splitter with headphones to monitor directly.
It worked perfect with your solution!
Thanks!
