Connecting a microphone [SOLVED]
How do I get Audacity to recognizing the microphone? The computer does, I can record, but not in Audacity.
Restart Audacity. Audacity looks for new devices when it starts.
Use the Audacity Device Toolbar to select input and output.
http://manual.audacityteam.org/o/man/device_toolbar.html
Well, yes… I’ve started and restarted a few times. If my device don’t show up in the list, I can’t make it work?
That was the end of simple question and answer. Now you get to tell us all about your system, microphone and connection. Part numbers, versions, makers.
http://www.kozco.com/tech/audacity/Documents/PostingQuestions2.pdf
Very suddenly it works! Problem was that recording volume was set to something very close to zero…
We have a winnah!!
