I"m a newbie with Audacity, so I could use some help. My operating system is Windows 7 Professional, with SP#1 (32 bit) installed. I downloaded Audacity v 2.0.5, with the .exe installer. I saw that to export MP3 files, I needed to download and install the lame file from the website recommended by Audacity. After i did this I restarted my system and restarted Audacity, when I checked the file section of the program to see if the Export function worked, it did not. I read the information on Installation, Start up and Plug-ins, and found information on conflicting lame files. I did a search and checked my system and found the following:
The lame file from the site recommended by Audacity was listed in the correct file C:Program FilesLame for Audacity. It contained the lame_enc.dll, modification date of 12/26/11, at 412 KB, also listed was (2) identical lame.enc.dll files in NERO which I use, with Modification dates of 8/1/2012, at 365 KB.
I know there is a conflict in .dll files, so do I rename the file in the Lame for Audacity folder to save it just in case, and then copy the later version from the NERO folder, into the Lame for Audacity folder, to get it working properly.
If you have had a similar problem, and resolved it, I would like to know how.
Thanks
CaptainVideo
