I am having trouble configuring version 1.3.6. (I also could not compile version 1.3.3 nor 1.2.6.)
I am making the source code on an AuthenticAMD i686 1666.766 MHz running linux kernel
2.6.18-8.el5 under Red Hat Enterprise Linux Client-hda (2.6.18-8.el5). I have wxWidgets 2.8.9
installed (and I can switch to wxWidgets-2.8.4 easiy if necessary). wxWidgets is installed in /usr/local/bin
and /usr/local/lib. Actually these are links to /usr/local/encap/wxWidgets-2.8.9/bin and /usr/local/encap/
wxWidgets-2.8.9/lib. After making and installing wxWidgets I did an ldconfig.
The audacity-1.3.6 source is installed in /usr/local/encap/audacity-1.3.6/src/audacity-src-1.3.6. The
configure command I used is
./configure --prefix=/usr/local/encap/audacity-1.3.6
The result of that is:
Warning: No config found to match: /usr/local/bin/wx-config --unicode=yes --ve
rsion
in /usr/local/encap/wxWidgets-2.8.9/lib/wx/config
If you require this configuration, please install the desired
library build. If this is part of an automated configuration
test and no other errors occur, you may safely ignore it.
You may use wx-config --list to see all configs available in
the default prefix.
configure: Checking that the chosen version of wxWidgets is 2.8.x
configure: error: Unable to locate a suitable configuration of wxWidgets v2.8.x
or higher.
The currently available configurations are listed below. If necessary, either
install the package for your distribution or download the latest version of
wxWidgets
from http://wxwidgets.org.
Default config is x11univ-ansi-release-2.8
Default config will be used for output
