# conan problems on windows build
**URL:** <https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675>\
**Category:** Compiling Audacity\
**Created:** [December 19, 2021, 5:59pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675 "2021-12-19T17:59:04Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![roadsterUK](https://forum.audacityteam.org/user_avatar/forum.audacityteam.org/roadsteruk/32/37115_2.png) [@roadsterUK](https://forum.audacityteam.org/u/roadsterUK)\
**Post date:** [December 19, 2021, 5:59pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/1 "2021-12-19T17:59:04Z")
</div>
I’ve just hit a few snags using the build instructions related to out of date conan references and SSL certificates. In a nutshell I had to:-
use **pip** to uninstall and then reinstall conan to get the latest version
use **conan remote** to remove and then add both conancenter and conan-center both of these pointing to
[https://center.conan.io](https://center.conan.io) rather than previous targets.
After this all was plain sailing ( but slow!)
**Author:** ![mike1504](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/m/82dd89/32.png) [@mike1504](https://forum.audacityteam.org/u/mike1504)\
**Post date:** [January 8, 2022, 2:58am UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/2 "2022-01-08T02:58:46Z")
</div>
I seem to be having this or a similar problem. Tried to do the suggested solutions, but I’m still getting errors. Perhaps not the same, or perhaps I didn’t know how to solve the problems. Any help would be appreciated. Here is the cmake output:
ERROR: wxwidgets/3.1.3.2-audacity: Error in source() method, line 168
os.rename(extracted\_dir, self.\_source\_subfolder)
PermissionError: [WinError 5] Access is denied: ‘wxWidgets-3.1.3.1-audacity’ → ‘source\_subfolder’
CMake Error at cmake-proxies/cmake-modules/conan.cmake:638 (message):
Conan install failed=‘1’
Call Stack (most recent call first):
cmake-proxies/cmake-modules/AudacityDependencies.cmake:255 (conan\_cmake\_install)
cmake-proxies/cmake-modules/AudacityDependencies.cmake:274 (\_conan\_install)
CMakeLists.txt:554 (resolve\_conan\_dependencies)
Thanks
**Author:** ![steve](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/s/f19dbf/32.png) [@steve](https://forum.audacityteam.org/u/steve)\
**Post date:** [January 8, 2022, 1:53pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/3 "2022-01-08T13:53:17Z")
</div>
Have you tried uninstalling Conan and then installing the latest version of Conan?
**Author:** ![werame5913](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/w/dbc845/32.png) [@werame5913](https://forum.audacityteam.org/u/werame5913)\
**Post date:** [January 15, 2022, 11:46am UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/4 "2022-01-15T11:46:39Z")
</div>
FWTW, I have similar conan errors on Windows:
```plaintext
ERROR: expat/2.2.9@audacity/stable: Error in source() method, line 36
        os.rename(extracted_dir, self._source_subfolder)
        PermissionError: [WinError 5] Access is denied: 'expat-2.2.9' -> 'source_subfolder'
  Conan install failed='1'
  cmake-proxies/cmake-modules/AudacityDependencies.cmake:255 (conan_cmake_install)
  cmake-proxies/cmake-modules/AudacityDependencies.cmake:274 (_conan_install)
  CMakeLists.txt:554 (resolve_conan_dependencies)
-- Configuring incomplete, errors occurred!
See also "M:/gh/aud-build/CMakeFiles/CMakeOutput.log".
See also "M:/gh/aud-build/CMakeFiles/CMakeError.log".
Never used conan before, so I don’t know how to debug them. Also, FWTW, this is what got installed through pip
```plaintext
>conan --version
Conan version 1.44.0
Apparently conan suffers from race conditions on Windows that even its devs don’t know how to debug [https://github.com/conan-io/conan/issues/5205](https://github.com/conan-io/conan/issues/5205)
Ok, maybe they did manage to fix it in the end, [https://github.com/conan-io/conan/pull/8915](https://github.com/conan-io/conan/pull/8915)
but apparently they’ve created a new api for that: tools.rename instead of os.rename.
Whatever Audacity is using (directly or indirectly) is apparently still using the old,
race-prone API os.rename. [https://github.com/conan-io/hooks/pull/294](https://github.com/conan-io/hooks/pull/294)
**Author:** ![jademan](https://forum.audacityteam.org/user_avatar/forum.audacityteam.org/jademan/32/39309_2.png) [@jademan](https://forum.audacityteam.org/u/jademan)\
**Post date:** [January 15, 2022, 12:14pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/5 "2022-01-15T12:14:51Z")
</div>
See this post: [https://forum.audacityteam.org/t/visual-studio-2019-16-8-3-has-a-bug-open-cmake-unknown-error/60836/1](https://forum.audacityteam.org/t/visual-studio-2019-16-8-3-has-a-bug-open-cmake-unknown-error/60836/1)
**Post date:** [January 15, 2022, 12:43pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/6 "2022-01-15T12:43:31Z")
</div>
Filed here [https://github.com/audacity/audacity/issues/2430](https://github.com/audacity/audacity/issues/2430)
Disabling the anti-virus or adding an exception for C:\Users\<YourUserName\>.conan is a temporary workaround. It’s usually the AV that causes rename races, but not the only source, the Windows search indexer can also cause these etc. There’s a special trick to avoid these races, IIRC, which robocopy is using. (I don’t remember the details, but it’s probably discussed in [https://youtu.be/uhRWMGBjlO8?t=506](https://youtu.be/uhRWMGBjlO8?t=506))
I’m like 75% sure the problem is that some other process (like the AV) opens a file in that tree without FILE\_SHARE\_DELETE. [https://youtu.be/uhRWMGBjlO8?t=818](https://youtu.be/uhRWMGBjlO8?t=818) Since conan downloads large zip packages with binaries in them, the AV will take a while to finish scanning them, and os.rename will fail in the meantime. Worth noting that I’m not building on the C: drive, which makes some tricks like moving files to %TEMP% fail, because they are non-atomic if you build on a different drive.
Although the cmake managed to build a whole lot after that (I turned off the AV), it still failed for me gain with a different kind of error… 😢
```plaintext
wxwidgets/3.1.3.2-audacity: WARN: Build folder C:\Users\WR\.conan\data\wxwidgets\3.1.3.2-audacity\_\_\build\137b263629b603e3e9a720b48b59cebe945627db
ERROR: wxwidgets/3.1.3.2-audacity: Error in build() method, line 260
        cmake.build()
        ConanException: Error 1 while executing cmake --build C:\Users\WR\.conan\data\wxwidgets\3.1.3.2-audacity\_\_\build\137b263629b603e3e9a720b48b59cebe945627db\build_subfolder --config Debug -- /m:4 /verbosity:minimal
This one is different in nature from the os.rename one, looks like some kind of permission problem. I guess I’ll take the invitation to discord for this.
Well, I found the root cause of that myself [https://github.com/audacity/audacity/issues/2431](https://github.com/audacity/audacity/issues/2431) Basically you have to use the x86\_64 cross-compiler for now, using the native x64 compiler will fail to compile libmp3lame, at least, and possibly other parts.
**Post date:** [January 26, 2022, 3:11pm UTC](https://forum.audacityteam.org/t/conan-problems-on-windows-build/63675/7 "2022-01-26T15:11:05Z")
</div>
Several times. along with python and all the build tools. It stops at the same place every time.
wxwidgets/3.1.3.1-audacity:
Configuring sources in C:\Users\Mike.conan\data\wxwidgets\3.1.3.1-audacity\_\_\source
ERROR: wxwidgets/3.1.3.1-audacity: Error in source() method, line 164
CMake Error at cmake-proxies/cmake-modules/conan.cmake:631 (message):
CMakeLists.txt:541 (resolve\_conan\_dependencies)
