Compression to bass heavy
I digitize a lot of allbums and cassettes……The signal is never strong enough so I use normalization and compression to bring the volume up….
But many times it makes the sound “bass heavy”….
My compression specs are….,.
Threshold -18db
Noise floor -40db
Ratio 4.1:1
Attack time .20 seconds
Release time 1 Sec….
Any recommendations on the settings to make the compression effect less “bassey”….
Thanks
Steve
ooops….Audacity 3.1.3…..
Another ooops….
:slight_smile:ass should read base….:slight_smile:
use a compressor plug-in whose detector circuit ignores the bass, e.g. TDR Kotelnikov | Tokyo Dawn Records , to avoid the bass pumping effect.
Sometimes it’s an iterative process… You compress and then go-back and EQ.
You might try limiting instead of compression. It’s easier to set-up and there are usually fewer side-effects.
If you don’t know this, limiting is a kind of fast-compression that pushes-down the peaks. Then you can use make-up gain or normalize to bring-up the overall volume.
But the limiter doesn’t have the noise-floor adjustment so it’s going to boost the noise along with everything else.
DVDdoug….thanks for the tip…..I have not used limiting and I will experiment with it…
