Hi All,
Just wondering why, when applying Compress Dynamics 1.2.6 to some files (so far it’s been only some samples I have recorded myself), the volume at the end will sometimes flare. I have attached an audio sample, for those interested in hearing it. Maybe this is a known problem with an easy answer. Or maybe the easiest answer is that I’m using a crappy mic - which I’m half expecting to be the case. But if the answer lies with compression settings or some other Audacity setting fix, that would be best.
Compression settings: Ratio .85, Hardness .5, Floor -32, Falloff 5.5, Max.Amp .99
Audacity 2.0.3 from .exe install
Windows 7
Thanks,
magnolia333
