I learned of someone who uses Steve’s PopMute effect with certain settings as a compressor for voice recordings – two or three times, alternating with amplification to a 0 dB peak.
Is this a surprising unintended use?
I use Compressor with certain settings and have been avoiding the temptation to experiment, but I may try out this curious method. Automating the repeated PopMute and amplify loop for my friend should be easy.
I am not sure what I want to listen for, to tell bad from good or very good results.
It’s an unintended use, but not hugely surprising. Users frequently find novel ways to do things. My attitude is “if it works for you, do it”
My guess is that he is using it as a kind of “Limiter”.
If you mean the built-in “Leveler” effect, then I completely agree. I’ve campaigned for that effect to be replaced for years!
The problem with the built-in “Leveler” effect is that it is not really a Limiter, it is a Wave Shaper (AKA a distortion effect).
The built-in “Compressor” effect is a bit quirky, (dynamic compressors frequently are), but can produce good results. You’ll need to play with it to get a feel for it, but it is reasonably well documented in the manual.
