Compile of SVN Audacity fails on Fedora 23 [SOLVED]
I’m currently attempting to compile the SVN version of Audacity on Fedora 23, x64.
As usual, all directions described on http://wiki.audacityteam.org/wiki/Developing_On_Linux#Compiling_on_Unix and http://wiki.audacityteam.org/wiki/Compiling_Audacity_for_Beginners#Step_2:_Download_and_uncompress_wxGTK have been followed.
Additional information about my setup:
  • I have ffmpeg and a bunch of additional libs scattered around /home/etna/Applications/GIMP/depends/lib and /home/etna/Downloads/avdepends/lib
My ./configure is as follows:
CFLAGS='-fPIC' LDFLAGS="-L/home/etna/Downloads/avdepends/lib:/home/etna/Applications/GIMP/depends/lib" CPPFLAGS="-I/home/etna/Downloads/avdepends/include:/home/etna/Applications/GIMP/depends/include" PKG_CONFIG_PATH=/home/etna/Downloads/avdepends/lib/pkgconfig:/home/etna/Applications/GIMP/depends/lib/pkgconfig:$PKG_CONFIG_PATH ./configure --prefix=/home/etna/Applications/Audacity --with-libvorbis --with-libflac --with-ffmpeg=system --with-lame --with-libid3tag --with-libmad --with-libsndfile=system
When running make, the build fails and claims that sndfile.h cannot be found even though it located at /home/etna/Downloads/avdepends/include as defined in the ./configure step, so i copied the .h files temporally to /usr/include and the build proceeded from there. However, it later fails with multiple errors about ffmpeg.h having conflicting definitions for a number of items. as shown in the pastebin link http://pastebin.com/N3BUnQHm
Any assistance will be greatly appreciated
The FFmpeg library can be a pain as there are frequently big changes between versions that break things when trying to link.
I’d suggest that you first try to build without FFmpeg (something like .configure --without-ffmpeg but check in .configure -h).
If that builds successfully, do
make distclean
then try configure with:
--disable-dynamic-loading
Thanks for replying. Building with --without-ffmpeg returned another set of errors at the linking stage: http://pastebin.com/pevYtgrk
It looks like another dependency is missing, but I can’t figure out what it is?
Doh, just noticed that you said “SVN version”.
Audacity no longer uses SVN - that’s the old, unmaintained Sourceforge repository. The current Audacity code is on GitHub, and it requires WxGTK 3.0 (preferably 3.0.2).
See: http://wiki.audacityteam.org/wiki/Developing_On_Linux
Trashed the SVN copy and cloned the GitHub version.
The Git version still fails with the same ffmpeg conflicts when built normally, but succeeded with --disable-dynamic-loading. I guess the issue is solved?
Excellent, that was quick - you must have a faster machine than me :wink:
I’m not sure why, but Audacity is a lot less fussy about the FFmpeg build when using --disable-dynamic-loading. It’s a workaround that Ubuntu uses on their repository builds. Audacity may eventually move from using FFmpeg to using GStreamer which will hopefully make this issue a thing of the past.
I’ll mark this topic as “solved”.
