compile failed in debian squeeze x64
There is log in attachments
I have ffmpeg develop pachages, but the problem seems happen in interior.
src is svn in goole code or the full src tar
audacity-log.txt (17.6 KB)
You need to provide the part of the log (and just above) that has the error.
sorry, I forget to use 2&1 >
here is the proble part
In file included from AudacityApp.cpp:70:
FFmpeg.h:355: error: 'SampleFormat' does not name a type
FFmpeg.h:572: error: use of enum 'SampleFormat' without previous declaration
FFmpeg.h:609: error: 'AVFormatParameters' has not been declared
FFmpeg.h:626: warning: 'av_register_protocol_fp' initialized and declared 'extern'
FFmpeg.h:626: error: 'URLProtocol' was not declared in this scope
FFmpeg.h:626: error: 'protocol' was not declared in this scope
FFmpeg.h:626: error: 'av_register_protocol' declared as an 'inline' variable
FFmpeg.h:626: error: expected ',' or ';' before '{' token
FFmpeg.h:679: error: 'AVFormatParameters' has not been declared
FFmpeg.h:685: warning: 'url_open_protocol_fp' initialized and declared 'extern'
FFmpeg.h:685: error: 'URLContext' was not declared in this scope
FFmpeg.h:685: error: 'puc' was not declared in this scope
FFmpeg.h:685: error: expected primary-expression before 'struct'
FFmpeg.h:685: error: expected primary-expression before 'const'
FFmpeg.h:685: error: expected primary-expression before 'int'
FFmpeg.h:685: error: initializer expression list treated as compound expression
FFmpeg.h:685: error: 'url_open_protocol' declared as an 'inline' variable
FFmpeg.h:685: error: expected ',' or ';' before '{' token
FFmpeg.h:691: warning: 'url_open_fp' initialized and declared 'extern'
FFmpeg.h:691: error: 'URLContext' was not declared in this scope
FFmpeg.h:691: error: 'puc' was not declared in this scope
FFmpeg.h:691: error: expected primary-expression before 'const'
FFmpeg.h:691: error: expected primary-expression before 'int'
FFmpeg.h:691: error: initializer expression list treated as compound expression
FFmpeg.h:691: error: 'url_open' declared as an 'inline' variable
FFmpeg.h:691: error: expected ',' or ';' before '{' token
FFmpeg.h:697: error: 'URLContext' has not been declared
FFmpeg.h:703: warning: 'url_close_fp' initialized and declared 'extern'
FFmpeg.h:703: error: 'URLContext' was not declared in this scope
FFmpeg.h:703: error: 'h' was not declared in this scope
FFmpeg.h:703: error: 'url_close' declared as an 'inline' variable
FFmpeg.h:703: error: expected ',' or ';' before '{' token
FFmpeg.h:859: error: expected initializer before '*' token
FFmpeg.h:865: warning: 'av_metadata_set_fp' initialized and declared 'extern'
FFmpeg.h:865: error: 'AVMetadata' was not declared in this scope
FFmpeg.h:865: error: 'pm' was not declared in this scope
FFmpeg.h:865: error: expected primary-expression before 'const'
FFmpeg.h:865: error: initializer expression list treated as compound expression
FFmpeg.h:865: error: 'av_metadata_set' declared as an 'inline' variable
FFmpeg.h:865: error: expected ',' or ';' before '{' token
FFmpeg.h:871: warning: 'av_metadata_set2_fp' initialized and declared 'extern'
FFmpeg.h:871: error: 'AVMetadata' was not declared in this scope
FFmpeg.h:871: error: 'pm' was not declared in this scope
FFmpeg.h:871: error: expected primary-expression before 'const'
FFmpeg.h:871: error: expected primary-expression before 'int'
FFmpeg.h:871: error: initializer expression list treated as compound expression
FFmpeg.h:871: error: 'av_metadata_set2' declared as an 'inline' variable
FFmpeg.h:871: error: expected ',' or ';' before '{' token
FFmpeg.h:895: warning: 'av_register_protocol2_fp' initialized and declared 'extern'
FFmpeg.h:895: error: 'URLProtocol' was not declared in this scope
FFmpeg.h:895: error: 'protocol' was not declared in this scope
FFmpeg.h:895: error: expected primary-expression before 'int'
FFmpeg.h:895: error: initializer expression list treated as compound expression
FFmpeg.h:895: error: 'av_register_protocol2' declared as an 'inline' variable
FFmpeg.h:895: error: expected ',' or ';' before '{' token
make[2]: *** [AudacityApp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory `/home/randy/src/audacity-src/src'
make[1]: *** [audacity] Error 2
make[1]: Leaving directory `/home/randy/src/audacity-src'
make: *** [build-stamp] Error 2
Which version of FFMpeg do you have installed?
Could you post the lines from immediately before the error lines.
The ffmpeg is from git
and the FFmpeg.h is in audacity src
g++ -c -I../lib-src/portmixer/include   -Wall -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -I../lib-src/FileDialog -I/home/randy/src/audacity-src/lib-src/lib-widget-extra        -I../lib-src/libflac/include -I../lib-src/libflac/include -I../lib-src/libid3tag -I../lib-src/libresample/include -I../lib-src/sbsms/include -I../lib-src/soundtouch/include -I../lib-src/libnyquist -I../lib-src/libvamp  -I../lib-src/twolame/libtwolame -I/usr/local/include   -I/usr/local/include   -I/usr/local/include   -I../lib-src/portsmf -I../lib-src/portaudio-v19/include -fno-strict-aliasing -I./include -I. -DLIBDIR="/usr/local//lib" -D__STDC_CONSTANT_MACROS   -Wall -pthread -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12     DeviceManager.cpp -o DeviceManager.o
g++ -c -I../lib-src/portmixer/include   -Wall -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -I../lib-src/FileDialog -I/home/randy/src/audacity-src/lib-src/lib-widget-extra        -I../lib-src/libflac/include -I../lib-src/libflac/include -I../lib-src/libid3tag -I../lib-src/libresample/include -I../lib-src/sbsms/include -I../lib-src/soundtouch/include -I../lib-src/libnyquist -I../lib-src/libvamp  -I../lib-src/twolame/libtwolame -I/usr/local/include   -I/usr/local/include   -I/usr/local/include   -I../lib-src/portsmf -I../lib-src/portaudio-v19/include -fno-strict-aliasing -I./include -I. -DLIBDIR="/usr/local//lib" -D__STDC_CONSTANT_MACROS   -Wall -pthread -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12     Envelope.cpp -o Envelope.o
I suspect the problem is that your version of FFMpeg is too new.
I’m using FFmpeg 0.7.13 “Peace” (and it works)
http://ffmpeg.org/download.html
Sorry I don’t know which of the other FFMpeg branches are compatible.
I see, thank you.
0.8.x should compile. The 0.8 version current when 2.0.0 was released in March compiled with Audacity.
