Compile error [SOLVED]
I’m trying to compile audacity on fedora 22 64-bits, but it fail on configure.
It gives me configure: error: ./configure failed for lib-src/libsoxr
./configure: line 17: cmake: command not found
If libsoxr is not present on the system, it has to be built from the source code (included in the Audacity source code). Building libsoxr requires cmake.
Nice, I just installed cmake and it works.
Thanks.
