Compare Tracks
I have two different recordings and I would like to display them and play them at the same time. Is it possible to open two files and have them both shown but in different tracks?
File > Import > Audio one and then File > Import > Audio the other. They should appear one over the other and play at the same time. Use the SOLO and MUTE buttons to change which one you hear.
e.g. …
