I do a lot of aligning of segments within a track (to match video)
If find it a bit annoying to have to switch back and forth between the select tool (only used used to position for a test playback) and the timeshift tool.
The multi-tool does not work for this as the segments are rarely at the end of the viewpanel (needed to shift in multi-mode)
It occurred to me that there is no function for the timeshift tool when it is not over a segment (is over empty part of track)
If the tool could act as a positioner (like when you click the track in select mode) when it is over empty track, it would save me many tool change clicks.
Not sure if what I am doing is a common use. If it is, please implement this small change.
Thanks!
