combining two projects
I have the beginning of a song saved as one project and the end of it saved as a second project. I’m looking to combine those as a single project with no break between them. Any suggestions? (Windows 7 using Audacity 2.0.2 from the .exe installer)
Export the “end” as a WAV file, then open the “start” project and import the WAV file.
Use the Time Shift tool to slide the “end” track to the right so that it is in the correct place (http://manual.audacityteam.org/o/man/tools_toolbar.html#timeshift)
Thanks. I was trying to accomplish this while keeping both parts in AUP format.
Then save the joined bits as a new AUP. You can’t append projects together - that’s a feature request.
