Combining tracks?
How do I combine tracks that will play at the same time? I’ve made sure their timing is right but I have no idea how to combine them. I have audacity 2.0.3 on my laptop. I’m kinda new to this thing, so can anyone help?
If you mean you have two tracks one above the other? Then File > Export.
Audacity will automatically mix down whatever you have into one track.
Did I miss a step? File > Import both songs. Tune as needed and then File > Export.
Yes, I meant one above the other, but both playing at the same time. Thank you, it worked. :slight_smile:
