clipfix
hi guys
im still in the dark about clip fix thing…how does it improve the lp and 78 files?is fixing them a good idea?
lenny
ps i just goe yet an exterior soundcard this one is by turtle beach…is this a good brand?
Click Removal. That’s the one that tries to figure out which sound is the drum and which is the cat hair on the record. It works remarkably well.
After all the cat hairs are gone, then you can use all the automatic loudness tools.
If you need Clip Fix for a record transfer, you’re recording it way too loud.
