I’m using 2.4.2 on OS 10.15.5. I primarily use Audacity to edit podcasts, so I do a lot of highlighting and removing of sections.
Something I recently started noticing is, when I highlight and remove a section, is that it is automatically copied to the clipboard. In other words, I don’t have to do Command-C for something to move to the clipboard.
Is this a new feature/setting? If so, can you show me how to change it?
Thank you!
David
