Hi! I have multiple clip boundaries of various lengths on different tracks. Sometimes, it occurs that the selection tool does not detect some boundaries and will not snap to them. Is there a setting I have to change to select which track’s clip boundaries I want to snap to? Thanks
Do you have Snap To checked (ticked): http://manual.audacityteam.org/o/man/faq_editing.html#snap ? If so, turn it off.
Also if the clip boundaries were labelled when Snap To was set to a high resolution format such as hh:mm:ss + samples, the Boundary Snap Guides may not appear when you reopen the project and drag to the labels.
No, Snap To is not checked and I never checked it while working with the project. It’s just some clip boundaries taking priority over others it seems.
Can you post a small example project online that demonstrates the problem?
We assume you are using the latest Audacity 2.0.5, of course: http://audacityteam.org/download/windows .
