Clicks on the audio recording.
Some recorded audio is getting crackles after recording, but it is an isolated environment and I don’t know how to resolve this bug anymore. Could they help?
Some small clicks that cause problems with my material.
Windows 11 22H2
Audacity 3.4.0
Are the crackles in the same or in different places each time you play it back. This will tell you if it is in the recording.
If it is in the playback, the possibly you are using bluetooth headphones which can cause these symptoms. You can try increasing the buffer length in Audio Setup > Audio Settings
If it is in the recording, you can try switching between MME and WASAPI, DirectSound works best for some. Turn off your browser, turn off you internet, make sure nothing else is running, reboot your computer.
