Hi, I record Let’s play commentary for a youtube channel. I use Audacity to record my voice and until recently, I have never experienced a single problem.
I recently bought a new computer, a HP Pavilion with 8GB RAM, and several sets of storage space, running Windows 10. I got all my recording software up; OBS for game capture, Logitech Quickcam for the face cam, and a Blue ICE Snowball mic recording on Audacity for the commentary; and started to go.
Now I’m editing the footage, and I’m noticing that there are a few seconds of audio popping or clicking occasionally, littered throughout the recording. It’s invisible when looking at the waveform; no peaks, gaps, spikes, or other signs of distortion; but it’s definitely noticeable when listening to the playback, and distorts the sound quite unquestionably. The clicking can be heard even when no sound is made, but is exacerbated by any kind of sound.
The playback device is “Speakers Realtek HD”.
I experimented with recording with only Audacity, and found that the clicks occur consistently around the 1:58 - 1:58 mark, and reoccur every two minutes or so. This regularity is consistent when after restarting the machine, unplugging and replugging the mic, using alternative USB ports, having the mic as the only USB to plug into the machine, swapping USB cables, moving the mic do a different place, putting the mic at the lower sensitivity setting, and unplugging the AC adaptor.
The clicking occurs when recording through the Snowball using Logitech Quickcam, so I’m not sure if Audacity is to blame, and I can confirm that the mic records just as well as it used to on my older computer (3.4 year old Windows 7 Sony Vaio), so I don’t blame the mic either. Just to confirm, my current laptop uses Audacity 2.1.1 while my old laptop uses Audacity 2.0.5
I checked recording using the Logitech Cam mic and the laptop’s inbuilt mic and have not encountered this problem, it seems to only happen when using the blue mic.
I have tried changing some settings in audacity, such as increasing buffer time to 1000 ms, but to no avail. I’ve included two mp3s in which you can hear the distortion. Both of them are snippets cut around the 1:57 mark. The timing is so consistent that I can predict quite accurately when the popping will start and end.
I have never encountered a problem like this before, and any attempt to remove the distortion digitally results in more damage done to the audio and no real effect on the distortion itself.
If anyone has any suggestions, advice, or even an explanation as to what might be going on, please let me know as I’m rapidly running out of ideas.
Thank you
