Hi
I hope you can help me! When I’m recording from the mic a click noise is appearing all along the recording, I was doing several tests and I found it appears as a shadow noise after every sound. I attached a couple of pics and sounds. As you can see after a clap there is a lot of clicks even if the gain is enough low.
Audacity version 2.4.1 (already uninstalled and re-installed)
O.S. Ubuntu 18.04
Sound card: VT1708S 8Canales High Definition Audio CODEC (Motherboard integrated ASUS m4a785td-v evo)
Input 1: LINE input (blue connector) with AKG P120 Condenser Mic
Input 2: MIC Input (pink connector) with web cam integrated mic. (I did a test with this to discard hardware issues)
Thanks in advance for your help!
