Cleaning up my music library
Hi, and thanks for reading.
I’m on Windows 10, using Audacity 2.1.2 installed from the .exe installer. I downloaded the program to clean up some issues in my music library, mainly clicks. Another recording I have has a sort of “squealing” sound to it, and I’m not sure how to fix it. I’ve attached a one-second extract for reference.
When I looked at the waveforms, I guessed that the source of the squealing is the rapidly undulating wavy bit in the bottom track (right channel), so I went ahead and muted the left channel and used the draw tool to smooth out the right track (bottom of the picture).
But when I play the edited track (with the left/top channel muted), though the squealing is decreased, it is still very noticeable. Here is the original extract:
Here is my edited version:
If anyone has any pointers about what I’m doing incorrectly, I’m all ears.
If you look at the spectrogram view there is a white-hot [loud] noise at 0.6s ~10kHz …
[ It sounds like a tweet if you play the track at half-speed ]
You can remove it using Audacity’s spectral edit tools
Thanks, that sounds a lot better.
I appreciate the links and pictures. Being so new to this, I don’t even have the vocabulary to know what to ask about.
