Clean up vinyl recording
Hi
Ive been trying to do something with this song but the final effect was very poor… The main tool used for me was a noise reductor, but after that i can hear a lot of metalic sounds in recordong. Can somebody help me give mi some advice ?
Here is a llink with audio:
http://www.divshare.com/download/16327542-ec7
Thank You!!
I’m a bit pressed for time so sorry about the brief reply, but there is an in depth tutorial about recording vinyl that you may find helpful: http://wiki.audacityteam.org/wiki/Transferring_tapes_and_records_to_computer_or_CD
and this workflow tutorial shoukd give you some guidance too: http://manual.audacityteam.org/man/Sample_workflow_for_LP_digitization
Thank You very much :slight_smile: I hope it will work a bit :slight_smile:
