Change volume of the original audio to the copy
Hi there
I want to set a macro with this function :
Get a audio track and copy this one to a second track (with the same audio)
Change the volume, to 10% higher and export to mp3
I know its simple, but Have no idea how to do that
Thank you in advance
Daniel
[advertising is not permitted on this forum]
Why do you need to copy the audio rather than just change the volume and export?
Which exact version of Audacity are you using? (look in “Help menu > About Audacity”)
So you could start with this:
Amplify:Ratio="1.0488176"
ExportMp3:
Amplify:Ratio="0.95345455"
I am not sure how to Export only a single track with a Macro, so rather than duplicate, I just modified the original track. (which I suspect is what steve was thinking…)
The Ratios were produced by Audacity, when I input +.414 and -.414, which I got from an online calculator as being equivalent to 110%.
I hope this helps. :smiley:
