I noticed that when I import a wav clip that there is about 3 seconds of dead space at the end of the track. How do I remove it?
Thanks,
Thanks,
Is there 3 seconds of silence at the end of the audio, or just 3 seconds showing on the timeline after the clip ends?
If it’s 3 seconds at the end of the audio, use standard Audacity editing techniques to delete it.
http://manual.audacityteam.org/index.php?title=Edit_Menu
You can’t change the length of the timeline. In fact, if you zoom out you’ll see lots of “extra” time at the end of the timeline.
– Bill
