Change Tempo plugin removed?
I seem to be unable to find the Change Tempo plugin in aud4, was it removed or renamed? Is there a way to add it back from aud3? My project is already converted over, and that is a requirement for my use-case.
Change tempo is not available as an effect in Audacity 4, it’ll probably get added in 4.1. In the meantime, you can use Soundscaper which has this effect added:
Or drag on the clocks to the left and right of the clip:
