Change Speed Default
In win 8-64, Audacity 2.0.4 seems to play back by default about half the speed it should be. While learning Audacity, I found the Effect > Change Speed control, when set to 100%, will correct this problem. It seems to have wrong initial setting.
How are you doing that?
It’s probably better to resolve the cause of this problem than just treat the symptoms.
