I made the stupid decision to “save as” data folder to desktop, which was not the Audacity default designation and then through some moving files, they automatically got deleted. I uninstalled and reinstalled audacity but now the default designation for “save as” is my desktop. I’m at a lost what to do as I can’t find the audacity folder.
The default Save directory (Windows) is:
*Documents\Audacity*
To reset Audacity:
“Tools menu > Reset Configuration”
Then Exit Audacity and restart.
Problem solved, thank you.
I’ll also try to set this folder to be avoided by Norton in case.
