Change Pan Settings?
Dear all,
I’m using version 3.1.3. Is it possible to change the pan setting (left/right) in the middle of a track, and then go back to the original setting later in the same track?
Thanks so much.
split new” copy of the middle section onto a new track, then adjust the pan setting of the new track.
The stereo-image will instantly change position at the edit, unless you use a crossfade.
