Change of Transport Options does not immediately apply
Audacity 2.3.0 on Win 7
I set the Transport Option “Software Playthrough” ON
I rand some tests, and decided I did not like that setting, so I then turned it OFF.
The setting remained ON until I restarted Audacity. This looks to me like a bug.
Works fine for me testing on W10 with 2.3.0 ( and the 2.3.1 alpha test vn.)
Note that if you have already turned monitoring on in the input meter without software playthrough turned on - and then turn on playthrough, the playthrough will not happen until you stop and restart the monitoring - or start recording.
