I’ve been using Audacity a little for several years, (currently version 2.0.0 from zip in Windows 7 64bit) but lost much of my vision a couple of years ago. Is there a way to change colors on the screen?
I find the position marker extremely hard to locate (black against blue and grey.) If I could change it to red or orange it would be much easier for me, and I imagine, some others. I would like it if the navigation buttons were a little brighter or darker too, but I can learn their positions to solve that.
As this program is always a work in progress, I hope someone can write or has written a simple color selection plug in. Thanks PR
“Theming” has been partially developed a while ago, but is unfinished, so disabled. You can see what it did here:
http://manual.audacityteam.org/man/Theme_Preferences
Meantime I’ll add your vote for more progress on customising colours.
Note that although there is no way to save and load themes from Audacity Preferences, you can still load a custom image cache file (if you can find one online) using the audacity.cfg file. There are some examples (and instructions) here:
http://jcsu.jesus.cam.ac.uk/~hdc21/design/audacity/ .
