Chains - Remove last X seconds before export
I am doing batch processing using the chains feature.
I need to cut the last 0.1 second from each file before exporting.
Is there a way to do this using chains, or some way through commandline options?
Best case scenario my chain would look like this:
  1. Normalize
  2. remove last 0.1 second from track
  3. Export OGG/MP3
This is the only thing I know about Chains.
http://manual.audacityteam.org/o/man/chains_for_batch_processing_and_effects_automation.html
Download TrimExtend.ny . To install TrimExtend, put it into the Plug-Ins folder inside the Audacity installation folder, then restart Audacity. TrimExtend will now be in the Chains command list.
In the Trim Extend parameters, choose “Seconds” and enter “-0.1” (without quotes) in the “Adjust end by” box.
