Chain 4 tracks for one continuous song
I have the 4 tracks sitting in audacity. Now I’d like to make them one continuous song. It seem there should be a way but I can’t find one to do this. What am I missing? Appreciate help.
Thanks.
You can “open” the 1st file but then “import” the rest of them so they end-up in the same project.
You can click & drag the name above the waveform to drag the tracks further-out in time.
When you export or play the files will be “mixed” but if they aren’t overlapped you’ll be mixing with silence.
You may also want to make crossfades, and either way you’ll want to zoom-in for a good transition where the tracks join.
Thanks much. Your info let me confirm what I’m now in process of doing.
Thanks again.
