CD track # ID
After creating, editing and saving a recording I can’t get the file to recognize divided clips into ‘track numbers’ (for the various songs). When saved and burned to a CD, only “Track 1” appears and the file is continuous, not separated into tracks as in a typical CD. I have created 'Silent spaces between the songs and, via Edit>Clip Boudaries> Detach at Silences I separated the songs identifying each as a track, which is what I want to see when (after burning the CD) playing the new CD on my Bose player.
see this tutorial in the manual: http://manual.audacityteam.org/o/man/splitting_a_recording_into_separate_tracks.html
and: http://manual.audacityteam.org/o/man/burning_music_files_to_a_cd.html
I normally use a [u]Cue Sheet[/u], and I burn with [u]ImgBurn[/u] (FREE!!!).
By using a cue sheet, you can burn your CD with from one or multiple audio files, with or without gaps. It’s very handy for making a continuous “live” CD without gaps, but with track numbers.
