I need to create a mono wav file 64kbps bit rate 8bit sample size in CCITT u-law format . I’m confused about the CCITT u-law part Please advise
I assume it’s just 8kHz, 8-bit, mono u-Law. Thats a fairly standard format for the telephone industry.
I found [u]this[/u].
Doesn’t the supplier of the software or system “demanding” this format provide a converter or encoder?
BTW - You don’t have to specify 64kbps… 8 bits x 8kHz x 1 channel = 64kbps.)
