Cassette Player Recording Issue - Please Help!
Hello,
Let me get the technical info out of the way:
Mac OS Catalina 10.15.2
Audacity 2.3.3
Pic attached to show my Audacity as I try to record
So, I have been using audacity on my Mac to copy cassettes to mp3 files on my computer for over 5 years and have had no issues. Well, finally that has lapsed. I tried recording and usually when I record, I listen to the audio as it records to make sure it didn’t skip, jump, etc… Well this time I wasn’t hearing anything.
This is because Audacity is not recording anything.
I have double checked everything I know how to check and even provided a screenshot to verify that I have the right input/output selected, etc…
**You will notice the microphone volume it at ZERO. I tried moving it to 100 and it drops back to 0 after a few seconds. Tried 25,50, and random numbers, always back to 0.
I plugged a headset into my cassette player as it was recording and the sound was playing fine through my headset, so I can rule out a bad cassette recorder.
I ran a malware scan to make sure a virus wasn’t messing with things, all good there.
I re-installed audacity, no help.
Restarted, unplugged, plugged back in, etc… to no avail!
Please help!! Thank you!
Audacity is not yet officially supported by Catalina, though for most, this workaround gets it going: https://forum.audacityteam.org/t/audacity-2-3-3-under-macos-10-15-catalina/54279/1
