Can't see the scroll during recording
When I record, the scroll of the recording goes off to the right, and then disappears behind the right-hand margin where I can’t see. It never used to do this. I need to see the recording as it’s being made so that I can adjust the volume as necessary. How do I fix this? There doesn’t seem to be a setting for this anywhere.
In Tracks Preferences make sure that Auto-scroll if head unpinned is checked “on” - see:
https://manual.audacityteam.org/man/tracks_preferences.html
Peter
Yea! Thank you! I guess I need this to be more than 20 characters to reply, but thanks!
