Hi -
I am using Audacity 2.1.1 on a Macbook Pro, OS 10.9.2.
The cut lines don’t show, even though I have them enabled.
What am I missing? (I am very new to this.)
Thanks so much!
- Char
Hi -
Thanks so much!
When enabled Cut lines should show when you “Cut” audio. Note that “Cut” and “Delete” are different. Cut lines do not appear where audio is “deleted”.
Oh, thank you, Steve. I misunderstood “cut lines.” When I’ve edited audio in Final Cut Pro, lines show when I’ve deleted sections.
Is there anything like this in Audacity?
Just use “Edit > Cut” (I think “Command + X” on Mac) rather than “Delete”.
Thank you, Steve! That works!! It finally makes sense to me. Grateful for your help.
