can't record
I am using Windows 7. Just using the mic from Toshiba laptop. I have no problem for the first recording. But in the second day, I got error message “Error while opening sound device. Please check the recording device setting and the sample rate.” I am just using default setting and make simple recording. I am an novice computer user. Is there any simple recording for starter? I have tried to change the settings but did not work. The help line does not address the problem. Thank you.
Still recording from the Toshiba mic?
See http://manual.audacityteam.org/o/man/faq_errors.html#sound_device.
