Hi all. I am no longer able to use Audacity to record system audio as I once was. The M-Audio card I used to have worked w/Audacity just fine for a long time, but I can not record anything with my new RME HDSPe AIO. I have tried every single option available, but nothing. Using W7 Ult 64-bit and Aud v2.
No - nothing there helps. I did see the “Windows Control Panel for sounds” section, but there is nothing there that helps, as the RME is already selected as the default device there.
So, in Audacity, I have selected:
MME
Analog 1&2 (RME)
2 (Stereo) recording
In my RME Mix Panel, I see the audio
This worked fine with the other sound card; I cant understand what happened here.
Please, give us the exact Audacity version (all three numbers) - see the pink panel at the top of the page. Don’t abbreviate. If yours really says “v2” it is a bogus version not made by us.
You also need to route the channels you want to record in Totalmix. Hit the X key and set the number of inputs you need. Then open Audacity and select the RME for input and output.
You M-audio is a very simple thing, compared to the RME that allows you to route anything to anything, including system audio. In Totalmix, you’ll get inputs and outputs, but also software playback. And all of that can be mixed and routed anywhere.
