Newbie… and I did something that has stopped Audacity from recording off the computer’s audio. Also the “recording device” tab under audio setup is greyed out. It was working fine, but I must have clicked the wrong thing, and now it won’t record.
Thanks
A wild guess… Can you select the Audio Host? You need to select WASAPI in order to then select loopback to record computer audio.
Thank you, that was the problem. It now works. I set up Recording Device to “Speakers” and now it works. Thank you again!
