I am trying to record an mp3 file using Line In, from spotify, but the recording meter hardly registers on the scale, and the track waveform just shows a flat line.
When I try to play the track back there is no sound.
I’ve looked through the FAQs and Help topics, but can’t see why.
OK, I understand now.
“Line In” is used when you want to record from something (such as a radio or an electric piano keyboard that is plugged into the “Line” recording input of the computer sound card.
To record sounds that are playing on the computer, the preferred method is to record from “Stereo Mix”.
Recording from “Stereo Mix” will record everything that is playing through the computer sound card.
Sadly support for “Stereo Mix” is gradually being phased out by Microsoft and many sound card manufacturers, but if it is available on your computer it is the most convenient method for recording what is playing on the computer.
The method is described here: http://manual.audacityteam.org/help/manual/man/tutorial_recording_audio_playing_on_the_computer.html
If you get stuck just give a shout and describe what/where you are stuck.
Sorry I didn’t get back to you last night. I don’t seem to have stereo mix on my computer. When I look in Volume Control/Properties/Recording there are only line in, rear mic and microphone - no stereo mix.
(dell inspiron Intel (R) Core ™2 CPU 6400@2.13GHz; windows version 4c29 3.95 EnhancedNT; XP Professional. )
Hi Steve Sorry to take so long to get back to you, but I got sorted out last night using the tip ‘if all else fails, you can connect a cable from the line-out (green) port of the computer to the line-in (blue), and choose the line-in as recording source’ and hey presto! Thanks very mcuh for your help. Papa Joe
