Can't open my project
HI! I need help. I cant open my project, it said error, if its uncompressed import raw data" I tried to open the help box n did the suggestion like downloading the ffmpeg but still I cant open my project. And also when I check the data theres nothing wrong with the file type n I never move or dekete or rename it. Can someone tell me whats happening n what should I do to open my project? Thx! #URGENT
An Audacity project has an AUP file and a _DATA folder of the same name.
They have to be in the same location, directory or folder for the show to open.
Close Audacity. Find the AUP file and double click it. The show should open in Audacity. Let us know if it doesn’t.
