I’m using Audacity 2.0.5 on OSX 10.8.5. I’m making cursory attempts at databending and have encountered a pretty basic problem, but I haven’t been able to find a solution.
I’ve imported about 20 different images and videos as RAW / U Law, RAW / A Law, or unsigned 8-bit PCM files. Even if I do nothing and just export the file using the same headerless settings with which it was imported, the new files can’t be opened. It makes no difference if it’s a tif, tiff, jpg, mov or flv file.
Is there some kind of setting in Audacity that could be preventing these files from opening?
Thanks!
